Few Bugs I noticed
general topics for the software
joeylites
Few Bugs I noticed
Post by joeylites »
A few things I noticed. I am using a Apple M2 Mac Mini on Sonoma.
I'm not a great computer guy I know it said to use Rosetta when on the M2 Chip but even though I have Rosetta installed on my mac It does not give me an option to launch with Rosetta (unless it does it automatically without notification) Anyway software loads and works with my interface.
I tested it with some Chauvet Intimidator Spot 360X and used the Intimidator Spot 360 profile rather than make my own.
I noticed in Board Creator when I create a pan/tilt board and enable the Shutter On and Dimmer 100% buttons it still does not enable it when using the movements. I had to go and edit each generator scene with Dimmer and shutter.
Also if you do not have the screen maximized the buttons do not expand properly and you cannot trigger some of the movements.
Re: Few Bugs I noticed
Thank you for your report.
Yes, your Apple Mac Mini M2 runs our software automatically via Rosetta without notification.
FYI, we will release later a "ARM native" (means run straight on M1 / M2 processor without using "Rosetta") version of our software. But this is not urgent since Rosetta does a perfect job.
Yes, you are right. We found some errors in our bank of DMX fixtures profiles. Sorry for that :oops:
We warned the users about that in this thread: viewtopic.php?t=56
The revised bank of profiles is available here: http://download.thelightingcontroller.c ... s_bank.zip
We will publish a new complete software setup with it asap.
In the meantime, you can manually replace it in your software folder.
Could you please post a link (via ImgBB for instance) of a screenshot showing this problem ?
