Betopper - BSW200
post here to submit a DMX fixture profile request
LOCOJESUDJ
Betopper - BSW200
Post by LOCOJESUDJ »
Hello, good afternoon. Could someone on this profile help me modify my original BETOPPER BSW200 file so it can work with Showexpress 1024? I'm new to this and don't know how to add it to my fixtures. Thank you very much.
<?xml version="1.0" encoding="utf-8"?>
<MA xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.malighting.de/grandma2/xml/MA" xsi:schemaLocation="http://schemas.malighting.de/grandma2/xml/MA http://schemas.malighting.de/grandma2/xml/3.3.4/MA.xsd" major_vers="3" minor_vers="3" stream_vers="4">
<Info datetime="2025-12-22T17:25:02" showfile="bsw200 dance" />
<FixtureType index="27" name="BSW200withRGB" mode="23ch">
<short_name>BSW200</short_name>
<manufacturer>BETOPPER</manufacturer>
<short_manufacturer>BETOPPER</short_manufacturer>
<Modules index="0">
<Module index="0" name="Main Module" class="Headmover" beamtype="None" beam_angle="1" beam_intensity="3000">
<Body>
<Size x="0.5" y="0.42" z="0.66" />
</Body>
<ChannelType index="0" attribute="PAN" feature="POSITION" preset="POSITION" coarse="1" fine="2" default="32767.5" highlight_value="50">
<ChannelFunction index="0" name="Pan" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="-270" physto="270" subattribute="PAN" subattribute_user_name="Pan" attribute="PAN" attribute_user_name="Pan" feature="POSITION" feature_user_name="Position" preset="POSITION" preset_user_name="Position">
<ChannelSet index="0" name="Pan" from_dmx="0" to_dmx="255" />
<ChannelSet index="1" name="Pan" from_dmx="0" to_dmx="65535" />
</ChannelFunction>
</ChannelType>
<ChannelType index="1" attribute="TILT" feature="POSITION" preset="POSITION" coarse="3" fine="4" default="32767.5" highlight_value="50">
<ChannelFunction index="0" name="Tilt" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="-270" physto="270" subattribute="TILT" subattribute_user_name="Tilt" attribute="TILT" attribute_user_name="Tilt" feature="POSITION" feature_user_name="Position" preset="POSITION" preset_user_name="Position">
<ChannelSet index="0" name="Tilt" from_dmx="0" to_dmx="255" />
<ChannelSet index="1" name="Tilt" from_dmx="0" to_dmx="65535" />
</ChannelFunction>
</ChannelType>
<ChannelType index="2" attribute="PT_SPEED" feature="SPEED" preset="SPEED" coarse="5" highlight_value="0">
<ChannelFunction index="0" name="PT_Speed" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="PT_Speed" subattribute_user_name="PT_Speed" attribute="PT_SPEED" attribute_user_name="PT_Speed" feature="SPEED" feature_user_name="SPEED" preset="SPEED" preset_user_name="SPEED">
<ChannelSet index="0" name="PT_Speed" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="3" attribute="DIM" feature="DIMMER" preset="DIMMER" coarse="6" highlight_value="100">
<ChannelFunction index="0" name="Dimmer" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Dimmer" subattribute_user_name="Dimmer" attribute="DIMMER" attribute_user_name="Dimmer" feature="DIMMER" feature_user_name="Dimmer" preset="DIMMER" preset_user_name="Dimmer">
<ChannelSet index="0" name="Dimmer" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="4" attribute="SHUTTER" feature="SHUTTER" preset="BEAM" coarse="7" default="254.999" highlight_value="100">
<ChannelFunction index="0" name="Shutter" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="SHUTTER" subattribute_user_name="Shutter" attribute="SHUTTER" attribute_user_name="Shutter" feature="SHUTTER" feature_user_name="Shutter" preset="BEAM" preset_user_name="Beam">
<ChannelSet index="0" name="Shutter" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="5" attribute="COLOUR1" feature="COLOR1" preset="COLOR" coarse="8" highlight_value="0">
<ChannelFunction index="0" name="Colour1" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Colour1" subattribute_user_name="Colour1" attribute="COLOUR1" attribute_user_name="Colour1" feature="COLOR1" feature_user_name="Color1" preset="COLOR" preset_user_name="Color">
<ChannelSet index="0" name="Colour1" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="6" attribute="GOBO2" feature="GOBO2" preset="GOBO" coarse="9" highlight_value="0">
<ChannelFunction index="0" name="Gobo1" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="GOBO2" subattribute_user_name="Select2" attribute="GOBO2" attribute_user_name="G2" feature="GOBO2" feature_user_name="Gobo2" preset="GOBO" preset_user_name="Gobo">
<ChannelSet index="0" name="Gobo1" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="7" attribute="GOBO2_POS" feature="GOBO2" preset="GOBO" coarse="10" highlight_value="0">
<ChannelFunction index="0" name="Gobo1 Rot" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="GOBO2_POS" subattribute_user_name="Index2" attribute="GOBO2_POS" attribute_user_name="G2&lt;&gt;" feature="GOBO2" feature_user_name="Gobo2" preset="GOBO" preset_user_name="Gobo">
<ChannelSet index="0" name="Gobo1 Rot" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="8" attribute="GOBO2 ROT" feature="GOBO2" preset="GOBO" coarse="11" highlight_value="0">
<ChannelFunction index="0" name="Gobo2 Rot" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Gobo2 Rot" subattribute_user_name="Gobo2 Rot" attribute="GOBO2 ROT" attribute_user_name="Gobo2 Rot" feature="GOBO2" feature_user_name="Gobo2" preset="GOBO" preset_user_name="Gobo">
<ChannelSet index="0" name="Gobo2 Rot" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="9" attribute="PRISM" feature="BEAM1" preset="BEAM" coarse="12" highlight_value="0">
<ChannelFunction index="0" name="Prism" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Prism" subattribute_user_name="Prism" attribute="PRISM" attribute_user_name="Prism" feature="BEAM1" feature_user_name="Beam" preset="BEAM" preset_user_name="Beam">
<ChannelSet index="0" name="Prism" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="10" attribute="PRISM ROT" feature="BEAM1" preset="BEAM" coarse="13" highlight_value="0">
<ChannelFunction index="0" name="Prism Rot" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Prism Rot" subattribute_user_name="Prism Rot" attribute="PRISM ROT" attribute_user_name="Prism Rot" feature="BEAM1" feature_user_name="Beam" preset="BEAM" preset_user_name="Beam">
<ChannelSet index="0" name="Prism Rot" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="11" attribute="GENERIC" feature="VIDEO" preset="VIDEO" coarse="14" highlight_value="0">
<ChannelFunction index="0" name="Generic" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Generic" subattribute_user_name="Generic" attribute="GENERIC" attribute_user_name="Generic" feature="VIDEO" feature_user_name="VIDEO" preset="VIDEO" preset_user_name="Video" />
</ChannelType>
<ChannelType index="12" attribute="ZOOM" feature="FOCUS" preset="FOCUS" coarse="15" default="127" highlight_value="49.8">
<ChannelFunction index="0" name="Zoom" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="ZOOM" subattribute_user_name="Zoom" attribute="ZOOM" attribute_user_name="Zoom" feature="FOCUS" feature_user_name="Focus" preset="FOCUS" preset_user_name="Focus">
<ChannelSet index="0" name="Zoom" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="13" attribute="FOCUS" feature="FOCUS" preset="FOCUS" coarse="16" default="127" highlight_value="49.8">
<ChannelFunction index="0" name="Focus" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="FOCUS" subattribute_user_name="Focus" attribute="FOCUS" attribute_user_name="Focus" feature="FOCUS" feature_user_name="Focus" preset="FOCUS" preset_user_name="Focus">
<ChannelSet index="0" name="Focus" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="14" attribute="SPEED" feature="SPEED" preset="SPEED" coarse="17" default="0.001" highlight_value="0">
<ChannelFunction index="0" name="Speed" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Speed" subattribute_user_name="Speed" attribute="SPEED" attribute_user_name="Speed" feature="SPEED" feature_user_name="SPEED" preset="SPEED" preset_user_name="SPEED">
<ChannelSet index="0" name="Speed" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="15" attribute="RESET" feature="CONTROL" preset="CONTROL" coarse="18" default="0.001" highlight_value="0">
<ChannelFunction index="0" name="Speed1" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="Reset" subattribute_user_name="Reset" attribute="RESET" attribute_user_name="Reset" feature="CONTROL" feature_user_name="Control" preset="CONTROL" preset_user_name="Control">
</ChannelFunction>
</ChannelType>
<ChannelType index="16" attribute="GOBO3" feature="GOBO3" preset="GOBO" coarse="22" highlight_value="0">
<ChannelFunction index="0" name="Gobo3" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="COLORRGB1" subattribute_user_name="R" attribute="COLORRGB1" attribute_user_name="R" feature="COLORRGB" feature_user_name="MixColor" preset="COLOR" preset_user_name="Color">
<ChannelSet index="0" name="Gobo3" from_dmx="0" to_dmx="255" />
</ChannelFunction>
</ChannelType>
<ChannelType index="17" attribute="GOBO3_POS" feature="GOBO3" preset="GOBO" coarse="23" highlight_value="0">
<ChannelFunction index="0" name="Control" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="COLORRGB2" subattribute_user_name="G" attribute="COLORRGB2" attribute_user_name="G" feature="COLORRGB" feature_user_name="MixColor" preset="COLOR" preset_user_name="Color">
<ChannelSet index="0" name="Safe" from_dmx="0" to_dmx="0" />
</ChannelFunction>
</ChannelType>
<ChannelType index="18" attribute="COLORRGB3" feature="COLORRGB" preset="COLOR" coarse="21" default="0.001" color="0000ff">
<ChannelFunction index="0" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="COLORRGB3" subattribute_user_name="B" attribute="COLORRGB3" attribute_user_name="B" feature="COLORRGB" feature_user_name="MixColor" preset="COLOR" preset_user_name="Color" />
</ChannelType>
<ChannelType index="19" attribute="COLORRGB2" feature="COLORRGB" preset="COLOR" coarse="20" default="0.001" color="00ff00">
<ChannelFunction index="0" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="COLORRGB2" subattribute_user_name="G" attribute="COLORRGB2" attribute_user_name="G" feature="COLORRGB" feature_user_name="MixColor" preset="COLOR" preset_user_name="Color" />
</ChannelType>
<ChannelType index="20" attribute="COLORRGB1" feature="COLORRGB" preset="COLOR" coarse="19" default="0.001" color="ff0000">
<ChannelFunction index="0" from="0" to="100" min_dmx_24="0" max_dmx_24="16777215" physfrom="0" physto="1" subattribute="COLORRGB1" subattribute_user_name="R" attribute="COLORRGB1" attribute_user_name="R" feature="COLORRGB" feature_user_name="MixColor" preset="COLOR" preset_user_name="Color" />
</ChannelType>
</Module>
</Modules>
<Instances index="1">
<Instance index="0" module_index="0" />
</Instances>
<Wheels index="2" />
<VirtualFunctionBlocks index="3" />
<FixtureMacroCollect index="5" />
<Body />
<AutoPresets index="4" />
<RdmNotifications index="6">
<RdmNotification index="0" Type="Absent" Subcategory="RDM Warning" />
</RdmNotifications>
</FixtureType>
</MA>
Re: Betopper - BSW200
We need the manual of the DMX fixture.
Please provide a link to download the manual of this DMX fixture and we will do the profile for you.
FYI: viewtopic.php?t=31
robertthompson
Post by robertthompson »
The .xml you pasted is a grandMA2 fixture file, so it won't import directly into ShowExpress 1024 — that console expects its own fixture library format. What you need is the fixture's DMX channel chart from the manual (channel numbers and what each one does), and from that someone can build the matching profile. The poster above already offered to do that once you provide the manual, so clarify what you actually mean by "original BSW200 file" — a pasted XML is not enough for them to map the 23 channels.
LOCOJESUDJ
https://betopperdj.com/products/betoppe ... head-light
This is the Betopper page; the manual is near the end. I’m trying to create my own fixture, but it doesn’t match up.
tanks again :
<?xml version="1.0" encoding="UTF-8"?>
<Model>
<Mode name="23CH" modified="TRUE">
<Channels>
<Channel dmx="0" name="Pan"/>
<Channel dmx="1" name="Pan Fine"/>
<Channel dmx="2" name="Tilt"/>
<Channel dmx="3" name="Tilt Fine"/>
<Channel dmx="4" name="Pan/Tilt Speed"/>
<Channel dmx="5" name="Master Dimmer"/>
<Channel dmx="6" name="Shutter/Strobe"/>
<Channel dmx="7" name="Color Wheel"/>
<Channel dmx="8" name="Static Gobo Wheel"/>
<Channel dmx="9" name="Rotating Gobo Wheel"/>
<Channel dmx="10" name="Gobo Rotation Speed"/>
<Channel dmx="11" name="Prism 1"/>
<Channel dmx="12" name="Prism Rotation"/>
<Channel dmx="13" name="Frost Effect"/>
<Channel dmx="14" name="Focus 1"/>
<Channel dmx="15" name="Zoom"/>
<Channel dmx="16" name="LED Ring Macros"/>
<Channel dmx="17" name="LED Ring Macro Speed"/>
<Channel dmx="18" name="LED Ring Red"/>
<Channel dmx="19" name="LED Ring Green"/>
<Channel dmx="20" name="LED Ring Blue"/>
<Channel dmx="21" name="Auto Run / Sound Modes"/>
<Channel dmx="22" name="Fixture Reset"/>
</Channels>
</Mode>
</Model>
