Request KEMAX - KM-MH13009EU - Sweetlight
post here to submit a DMX fixture profile request
Lucxueus
Post by Lucxueus »
I would like to request a DMX fixture profile for the following lighting fixture:
Brand: KEMAX
Model: KM-MH13009EU
Software: Quick DMX V_II
Software version: 0.1.46
DMX mode: 86 channels
Fixture type: 10x40W Snake Light + Ring
The fixture has 10 individually controlled motor channels and 10 RGBW LED sections, plus individual cool white and warm white auxiliary LEDs.
The fixture dimensions are:
Length: 880 mm
Width: 100 mm
Height: 200 mm
I have the original manufacturer's manual containing the complete 86-channel DMX table.
Could you please create the fixture profile for SweetLight classic?
If possible, I would also appreciate support for the 10 individually controlled moving heads in the fixture setup.
Thank you!
robertthompson
Re: Request KEMAX - KM-MH13009EU - Sweetlight
Post by robertthompson »
To get this built, the 86-channel DMX table itself needs to be in the thread — paste the chart or attach the manual PDF with channel numbers, function names and value ranges. It would also help to state whether you want a single 86-channel profile covering the whole fixture, or separate profiles for the 10 moving heads, the RGBW sections and the CW/WW auxiliary LEDs, plus how much DMX space you plan to leave between fixtures. With that posted, the profile request is much easier to act on.
