DMX channel - visual map
declare your DMX fixtures
Pauluzzz
Post by Pauluzzz »
In the fixture creation module, we now have just a list of fixtures with their corresponding start and end DMX addresses. I miss, though the visual map that shows where all the addresses go and where there still are open channels left. This is more painful as there is no option to change addresses automatically. I can do without the map, but automatic change/update/fix addressing should be available though....
Re: DMX channel
The problem is the visual map is not small screen friendly.
Please note that the overlapped and available channels are clearly highlighted.
Pauluzzz
Re: DMX channel - visual map
Post by Pauluzzz »
The error indication is great, absolutely, next step would be that in case of such an error to provide an option to suggest a new DMX channel numbering scheme that is calculated automatically (with option to avoid certain ranges, keep some fixtures as they are, etc.). I can do without a map, it was just very convenient. :roll:
Happy that you can do with the error indication.
And this is noted for the option to suggest a new DMX channel numbering scheme.
LightMaster
Post by LightMaster »
Can you have an option for Mac OS and Windows computers with normal screens to enable the visual table? I'm already missing that.
