				Palettes / presets
				Posted: Fri Mar 15, 2024 12:42 am
				by Dumbfungus
				Is there a function similar to palettes?  I want to have pre-defined positions for my moving fixtures.  I would like to be able to set different pan positions, and tilt positions.  Then be able to mix and match.
				Re: Palettes / presets
				Posted: Fri Mar 15, 2024 11:39 am
				Not now.
Noted.
				Posted: Sun Jun 16, 2024 7:20 am
				by Vladimix
				+1, or like save shape function
				Posted: Wed Jun 19, 2024 6:50 pm
				Regarding the word "palette".
Solution #1
It is ok whether this palette is a pan/tilt position that can be saved from one scene and loaded in another one. And afterwards, if you want to change this pan/tilt position, you will have to change it in all scenes.
Solution #2
Or does this palette have to be an ID linked to a pan/tilt position. Afterwards, you can change the pan/tilt position and all scenes using this ID will automatically have the pan/tilt position updated with the new one ?
To know:
first case should be quite easy to achieve, while the second one is another story.
				Posted: Tue Jul 02, 2024 4:55 am
				by Dumbfungus
				I really like the way it works in the previous v9 software.  I can save specific RGB combinations , xy coordinates , etc.
I’d like to be able to define settings and use them in scenes.  So if I update the setting then all instances of that will update automatically.
				Posted: Tue Jul 02, 2024 9:45 am
				Thank you for this information.
This is noted.
				Posted: Wed Feb 26, 2025 9:41 pm
				by SebGdrt82
				+1
				Posted: Mon Jul 28, 2025 2:08 am
				by RyanF
				++++++1!!!!  This is what is keeping me from using this program.   Why can't you save a color or a pan tilt position that you can easily open in generator. Seems to me this should be a given with a program like this.
				Posted: Mon Jul 28, 2025 9:59 am
				Looks like you are asking for "solution #1", while "solution #2" was previously asked in this thread.
Noted anyway.
