Event Lighting - LM7X12W
Posted: Tue May 13, 2025 1:22 pm
by johnnymack
I need a profile for Event Lighting LM7X12W Moving Head fixture
PDF User manual on this page:
https://eventlighting.com.au/products/lm7x12w
Thanks!
Re: Event Lighting LM7X12W
Posted: Tue May 13, 2025 3:35 pm
The link says "Page not found".
Could you please check that ?
Posted: Wed May 14, 2025 5:53 am
by johnnymack
Hi, thanks for looking at the profile creation
Strange, the link works for me.
And also the link on the web page to the user manual pdf works for me.
Try this direct link to the pdf:
https://cdn.shopify.com/s/files/1/0304/ ... 3529217809
Here is the general information if that helps:
Power
Input Voltage: 100~240V AC, 50/60 Hz
Power Consumption: 95W
Connection: IEC in
Fuse: T2A, 250V
Photometric
Light Source: 7 pcs 12W RGBW LED
Beam Angle: 6° - 40°
Output: 9500lux @ 3M
PWM: 3000Hz
LED Lifespan: 20,000 hours
Effects
Dimming: 0~100%
Strobe: 1~20 Hz
Zoom: 6° - 40°
Movement 8 / 16 – bit
Pan: 540° (1.4 sec)
Tilt: 190° (0.8 sec)
Posted: Wed May 14, 2025 6:04 am
by johnnymack
Here are the DMX assignments from the user manual
Thanks again!
DMX Chart
15 channel Mode
Channel Value Function
1 000 - 255 Pan Coarse
2 000 - 255 Pan Fine
3 000 - 255 Tilt Coarse
4 000 - 255 Tilt Fine
5 000 - 255 XY SPEED
6 000 - 255 Dimmer(0-100%)
7
000 - 009 Shutter closed
010 - 245 Strobe effect slow to fast
246 - 255 Shutter open
8 000 - 255 Red
9 000 - 255 Green
10 000 - 255 Blue
11 000 - 255 White
12 000 - 255 Color Temp
13
000 - 010 closed
011 - 020 R
021 - 030 G
031 - 040 B
041 - 050 W
051 - 060 R+G
061 - 070 G+B
071 - 080 B+W
081 - 090 R+B
091 - 100 G+W
101 - 110 R+W
111 - 120 R+G+B
121 - 130 R+G+W
131 - 140 G+B+W
141 - 150 RGBW
151 - 255 Jump from slow to fast
14
000 - 010 Macro Color Line (Disable)
011 - 255 Slow from slow to fast
15
000 - 020 No Function
021 - 040 Internal program 1
041 - 060 Internal program 2
061 - 080 Internal program 3
081 - 100 Internal program 4
101 - 120 Internal program 5
121 - 140 Internal program 6
141 - 160 Internal program 7
161 - 180 Internal program 8
181 - 200 Empty
201 - 225 Motor Reset
226 - 255 Empty
16 0-255 Focus
Posted: Thu May 15, 2025 12:02 am
Thank you for these details.
The profile is done.
Re: Event Lighting - LM7X12W
Posted: Thu May 15, 2025 3:37 am
by johnnymack
Thank you!
That is great.
Best
John
