Problem with a sound file (delay, wave form) [fixed]
Posted: Sat Nov 08, 2025 9:41 pm
by sebastian
Good evening,
I have a problem with playback in the timeline. When I start the timeline, the light tracks are fine, but the music is delayed by 2-3 seconds. I use music in WAV format (PCM 16 bit, 44100 Hz, stereo). I know that the program has a different encoder than other audio software. I read about it on the forum, but I don't know how to fix it. Thank you.
Re: problem with music in lime line
Posted: Sun Nov 09, 2025 12:48 am
Could you please send us the audio file + a ZIP of your lightshow via wetransfer ?
(viewtopic.php?t=101)
We will check that.
Posted: Sun Nov 09, 2025 2:37 pm
by sebastian
The problem persists in all light shows, even if I create a completely new one and only import music, the problem still persists:
Music: https://we.tl/t-F4X9a7Gm5f
I also used the first version of the software, where I used the timeline once and had the same problem.
Posted: Mon Nov 10, 2025 5:06 pm
You sent only the audio file without your lightshow, so we tested only the audio file, and it works ok here.
We suspect a Codec problem in your system.
We suggest you to install "K-Lite Codec pack": https://www.codecguide.com/download_kl.htm .
Posted: Tue Nov 11, 2025 7:00 am
by SmallFrog127
support wrote: Mon Nov 10, 2025 5:06 pm You sent only the audio file without your lightshow, so we tested only the audio file, and it works ok here.
Hello! :)
I am having the same issue i believe. I installed a Ubuntu equivalent of the codec and I am still having issues. I noticed in the console it said "
Code: Select all
Failed to initialize QMediaPlayer "Not available"
TimeLine::loadWaveForm : m_audioDecoding timeout
" when I tried importing the .wav file. The wave form is still not showing up nor is it playing. I hope this helps.
Posted: Tue Nov 11, 2025 9:25 am
If we right understand, these problems (wave file not visible and error message) are with the file stored here: https://we.tl/t-F4X9a7Gm5f (?)
FYI, no problem with this file here on our Debian system, and Debian is quite close to Ubuntu.
We will however investigate based on possible differences.
Posted: Thu Nov 13, 2025 4:46 pm
Could you please tell us the exact version of your Ubuntu system ?
And the processor (Intel, Arm) ?
Posted: Thu Nov 13, 2025 9:26 pm
by sebastian
I installed https://www.codecguide.com/configuratio ... rsion=1930 and the problem is solved. It works perfectly for all songs, regardless of type.
Thank you very much. :D
Posted: Fri Nov 14, 2025 9:14 am
Good news !
Thank you for the feedback.
