Art-Net issue
general topics for the software
EKO-LSS
Art-Net issue
Post by EKO-LSS »
I’m trying to expand my setup by adding a Node 4 (Art-Net/sACN) alongside my D1024, but I can only get one universe to link to the node.
My Current hardware includes
Software: The Lighting Controller II
USB interface: D1024
Network node: Node 4 (Art-Net/sACN)
Working configuration
Universe 1 → D1024 → Port ID 0 ✅
Universe 2 → D1024 → Port ID 1 ✅
Both of these work correctly.
What I’m trying to do
Use the Node 4 for the next universes:
Node Port 1 → Universe 3
Node Port 2 → Universe 4
Node Port 3 → Universe 5
The issue
Only Universe 3 links to the node.
If I set all node ports to the same Port ID (2) they all output DMX, but they behave as a splitter for Universe 3, not as separate universes.
So the node itself is working — I just can’t get the other universes to map independently.
Also the gear item does nothing when configuring the interface IP address in the Hardware tab of
The Lighting Controller II, is that where i should have been able to configure which ports are mapped to which Artnet node
My Goal
D1024 → Universes 1–2
Node 4 → Universes 3–5 (each port its own universe)
Any guidance on the correct universe/Port-ID mapping or required software settings would be greatly appreciated.
Thanks!
Re: Art-Net issue
The interface D1024 is able to control 1536 channels (3 universes).
The two first universes can be controlled either via DMX or via Art-Net.
The third universe can be controlled only via Art-Net.
EKO-LSS
Re: Art-Net issue
Post by EKO-LSS »
:| oh shooooottttt,
what a waste, i literally thought these were 3 additional universes,
not an either or option.. sigh..
that's really a low blow....
in that case, it might be best, that you guys allow persons to buy direct artnet licenses..
what's sense of carrying around the D1024 just to plug it in as a key, with no connection to any fixture, since i have to now carry an additional artnet node to get 3 universe?
why not just sell artnet keys/licenses to persons who rather utilize the artnet protocols?
