Hi, good day,
I have a few workflow questions and feature requests regarding The Lighting Controller II, as well as one issue I’ve encountered:
1)Adding multiple generator buttons to a card
Is there a way to add multiple generator buttons to a card at once? Currently, adding buttons one by one requires repeatedly navigating back and forth, which can be time-consuming. The previous version of SweetLight allowed adding multiple buttons at once, which was much more efficient.
2)Direct RGB value entry / RGB faders
Is there a way to enter direct numeric values into the RGB color picker for RGB fixtures?
Alternatively, could an option be implemented to switch between the color picker and individual R, G, B faders, allowing for precise value entry and adjustment?
3)Multiple Child Windows
Is it possible to create and use multiple Child Windows simultaneously? If not, is this functionality planned?
4)Follow spot pan/tilt joystick mapping
Can the follow spot pan/tilt pad be mapped to a joystick or external controller axis?
5)Generic user-assignable faders
Would it be possible to implement a generic “Fader” option for fixture customization?
For example, if a fixture has a “Focus” channel, I would like to:
Add a generic fader labeled “Focus” in the fixture profile
Map that fader to a generic fader in the fader board
Use it to control the fixture’s focus channel directly
At the moment, only Dimmer and Speed faders appear to be supported.
6)Fixture response issue in version 0.1.31 (18 December 2025)
In version 0.1.31 (18 December 2025), fixtures appear correctly in the 3D window, but they do not respond to controls from the software. There is no visible movement or beam output when operating the fixtures.
I have tested this on two separate Windows computers, both exhibiting the same behavior. I have also verified that this is not related to my show file, as the issue persists when creating a new, independent light show in version 0.1.31 using fixtures directly from the fixture bank.
Thank you for your time, and I appreciate the continued development and improvement of SweetLight.
p.s: I’ve also noticed similar reports from at least one other user on the forum describing the same behavior in version 0.1.31, including lack of beam rendering and pan/tilt movement in the 3D View, even when testing with default lightshows.
Feature Requests & Fixture Response Issue – v0.1.31 (Windows)
Re: Feature Requests & Fixture Response Issue – v0.1.31 (Windows)
Thank you for this report.
Please see below our answers.
1.
We do not understand this question, because the V9 and V_II software methods are similar:
- select the buttons with the check mark
- select the menu "Add selected buttons" in the Macro button
2.
This is currently not possible.
This is noted.
3.
Only one child window is possible.
This means you need 2 monitors to see the main window and the child window.
That said, the number of pages (= child window in V9) is not limited.
4.
This is noted.
5.
The "Board Creator" allows to generate Preset buttons with a slider to go from min level to max level.
But this function does not work with a "pur" (no levels) channel.
This is noted.
6.
This is fixed in the new version 0.1.33 (Windows only).
1.
2.
This is noted.
3.
4.
This is noted.
5.
This is noted.
6.
Thanks for the Reply..
RE:
my question was not in reference to adding buttons to a macro button. (am not sure how to add images, so i will try to explain a bit more clearly.
1) Add Board
2) Add Buttons board
3) Add button
4) Add Generator button
5) Choose a Generator Project (only one can be selected/added at a time. So incases where multiple generator projects are to be added, steps 3 to 5 are to be repeated multiple times)
eg:
1) Add button
2) Add Generator button
3) Choose a Generator Project (button1)
1) Add button
3) Choose a Generator Project (button2)
1) Add button
3) Choose a Generator Project (button3)
and so on.. it would be greatly appreciated if we could select multiple generator projects at once, eg:
1) Add button
3) Choose Generator Project/s (button1, button2, button3, etc)
Re:
3.
yes i am aware that multiple monitors are needed. I currently run a two monitor setup, however, I am looking to build a 3 monitor setup. to accomplish this, i need at least two child windows in addition to the main window. The amount of pages isn't an issue. but would be grateful for at least 2 child windows.
RE:
1) Add Board
3) Add button
eg:
1) Add button
1) Add button
1) Add button
1) Add button
Re:
3.
1.
Understood. This could be fixed with multi-selection files in the "open Generator files" window.
This is noted.
3.
We note that two child windows would be welcome for user with 3 monitors setup.
Thank you again for your comments.
This is noted.
3.
Pan & tilt have up to 65535 positions.4)Follow spot pan/tilt joystick mapping
Could you please tell us more about your wish ?
Could you show the item you wish our follow spot works with ?
Thanks for reaching out..
am thinking more along line of using two rotary encoders (knobs) as opposed to a joystick.. 1 for the Pan and 1 for the tilt.
Basically adjusting the pan or tilt independent of each other.. I can set the tilt and freely pan left or right, keeping the same tilt
unless i adjust it. would be a nice touch for the generator as well.
Thanks for the clarification — that makes sense.
In principle, using rotary encoders for pan and tilt control is an interesting idea. However, in practice, this type of controller can be quite tricky to support reliably.
The main issue is that there is no real standard for how endless rotary encoders send MIDI data. Different devices use different methods, which makes it difficult for us to ensure consistent and predictable behavior across all hardware.
We have already encountered compatibility issues with some existing products, which is why we have to be cautious with this type of implementation.
That said, do you have a specific controller model in mind, or a device that you are currently using ? If there is a well-defined reference, it may help us better evaluate what could be possible.
I would like them mappable to any of the knobs on an apc40 mk2..(but my total kit includes, 3 touch monitors, 1 apc mini mk2 and 1 apc40 mk2)
i understand that it may be a bit tricky, but it would be a nice step up for The Lighting controller II.
You have added follow spot, which i find is a nice touch. giving the user the flexibility to grab any moving fixture on
the fly and maneuver it as please..
but the practicality of the current maneuvering is the issue... it takes a bit of back and forth to get the fixture where you want. and you got
to constantly hold the mouse click while doing so, cause the moment you let go, if you don't click back in the
exact spot, the fixture jumps to the location of the new click.. now you have to do the dance all over again to get back to
where you need it to be.
side note..
the fact that we are having this dialogue, is already a plus in my books.. it shows that you not only listen to your users, but you engage them for
clarity rather than brushing off the idea.. all the best to you and your team,, and i look forward to the news of the update comining soon..
side note..
I was experimenting with the possibility of using MIDI encoders/knobs to control pan and tilt, and the results were very promising.
For testing, I used a 4-channel dimmer pack configuration. I created a generator button for the fixture, enabling only the pan and tilt channels, and used that as my follow spot on/off, with priority set high. I then mapped the pan and tilt channels to dimmer faders in the software, and assigned those faders to two knobs on the APC40.
The result was exactly what I was looking for: independent pan and tilt control using rotary knobs.
This works very well for positioning a fixture to a specific point, and in my opinion it is easier to control as a follow spot than the current built-in follow spot feature.
Downsides:
1. Because the pan and tilt channels are configured as dimmers in the fixture profile, I am unable to create generator scenes in the 3D Visualizer.
2. Unlike the built-in follow spot feature, I cannot grab a random fixture on the fly and use it immediately as a follow spot or point it to a specific location. With this method, I would need to create an override button and fader channels for multiple fixtures in advance, just in case I need one from a particular angle.
Possibilities / Feature Ideas:
1. Instead of trying to map the entire 65,000+ pan/tilt range directly to a rotary knob, would it be possible to assign MIDI control to the dot/pointer that hovers over the pan/tilt grid, almost as if it were being moved by a mouse? For example, one knob for up/down and one knob for left/right.
2. Would it be possible to add an option within the current follow spot board to replace, or switch from, the pan/tilt grid to two assignable faders, while keeping all the existing functions such as random fixture selection, priority override, and the spot button/presets?
Side note: I was able to get the full pan/tilt range using the knobs, the movement needs a little fine-tuning to make the movement smoother, but overall the concept works very well.
Downsides:
