Problem with truss
3D view of the lightshow
flipc
Problem with truss
Post by flipc »
So expand the Truss video to show single segment shape construction.
I just tried it.
Steps followed:
Edit Mode = ON
Open Truss Creator:
Choose Segment Shape. Change Type to Triangle, Color RED , Set length 16 Feet (Feet set in settings).
Put a name in Group box (Horizontal Truss) and assign a Key = t
Hit OK
Popup opens to set positioning but nothing is on screen.
Close that. Go to Group control top right. Its there. Can reopen Positioning control pop up. Still nothing shown.
So Use the + bottom right.
Select Truss - Triangle 2M Segment.
Segment appears with positioning popup.
If I input a number into an axis and hit enter it does nothing.
The +/- buttons do work BUT that is allot of wasted time trying to position item.
And the straight 3 dot ICON top right should be replaced with a BINOCULAR icon.
Makes way more sense for VIEW.
Re: Problem with truss
Noted.
We will try to reproduce these problems.
We have to be able to reproduce them to fix them later.
Please note that a video showing the problem may help a lot.
Noted.
flipc
Post by flipc »
Curious if you were able to recreate this issue?
I had to put V II aside for a few due to work and just now have gotten back to sorting it out.
Downloaded latest version and will retry this to see.
No we were not able to recreate the issue.
In case of you still reproduce it, please post a video showing how to proceed.
