request - smooth fade for Color Board
Deestage
Post by Deestage »
Dear Support,
please add a feature to select a "smooth" for color change via color boards.
I think it would be great if I tapped on a color and then a smooth transition would automatically occur.
Thank you
Re: Smooth Fade for Color Board
Smooth transitions when pressing a "color preset" button from the "Color board" ?
Please confirm.
Deestage
Post by Deestage »
let me put it in other words.
If I press a saved color in the color board, the DMX vaule snaps to that color. I would like to add a fade for that transition.
Understood and noted.
sector7g
Post by sector7g »
To piggyback off what Deestage mentioned, it'd also be great to have the ability to fade from full to off. (100% to 0%). Showxpress (previous version) currently has the Flash button, but doesn't have the ability to assign a fade instead of the "hard off".
Also for any fade, the ability to set the duration of said fade (.25 seconds, 2 seconds, etc.). I believe MagicQ has this function and it really helps dress up a light show.
Thanks, and appreciate what you are building!
Thank you "sector7g" for your feedback and your comment.
Both options "fade in" and "fade out" are noted for the memory buttons of the Color boards.
