Some bugs, or me!
general topics for the software
sapian
Some bugs, or me!
Post by sapian »
Noticed using a scroll wheel in the Board creation window does not scroll correctly.
When I create a master dimmer board it starts at 0 and the dimmer only pulls down to negative- no light, also, 3D Beams switch not selectable.
When creating fixture from scratch the starting and ending numbers in channels levels would change after saving, had to edit again to save. Also, seems what is selected effects values when entering new levels properties.
MBpro M4pro
sapian
Re: Some bugs, or me!
Post by sapian »
Understand why Beams would not be selectable in Boards. Saw earlier post about levels in dimmers in fixture profiles was causing problems. I deleted Dimmer levels but still no light output in 3d. Still have dimmers that start at top at 0 and pull down to -100, counterintuitive. The ADJ Focus spot 2's profile I loaded had lots of errors in them besides the "dimmer level" issue. Corrected them all but still no go.
sapian
Post by sapian »
Slowly figuring out... Things work ONLY when you use the "Board Creator" AND switch ON 100% Dimmer, Shutter and Iris. Manual creation of dimmers doesn't work as you are never given those choices.
Yes, in the module "Boards" of our new software V_II, the master faders "dimmer" go from 0 to -100%.
Please post a video showing the color wheel problem.
The switch "3DBeam" is used exclusively for programming modules (Fixtures / Groups / Generator).
Noted for the levels values in the module "Fixtures" > "Edit profile".
