Help Import Fixture FIle
declare your DMX fixtures
MattCarlsen
Post by MattCarlsen »
Hello All,
So I read the FAQ and am missing a step somewhere.
I found my fixture here: before_2025_10_10/uking_zq01082
If I save as txt - Import sees the file - but Importing does nothing I can see
If I save as XML - then import does not see it
Do I need to convert XML to Text?
thanks in advance
-matt
When I save as XML or TXT ... the file content looks like this. This is not like other fixture files I see in the folder
C:\Program Files\ShowXpress\TheLightingController\editor_fixtures_bank\UKing
<Model>
<Mode modified="TRUE" name="Default">
<View>
<Type>VIEW_TYPE_PARCAN</Type>
<Power>VIEW_POWER_2</Power>
<AnglePan>0</AnglePan>
<AngleTilt>0</AngleTilt>
<AngleBeam>24</AngleBeam>
<AngleBeamZoom>24</AngleBeamZoom>
<ReversePan>FALSE</ReversePan>
<ReverseTilt>FALSE</ReverseTilt>
<ReverseDimmer>FALSE</ReverseDimmer>
<ReverseIris>FALSE</ReverseIris>
<Color>#ffffff</Color>
</View>
<Channels>
<Channel name="dimmer" path="dimmer/"/>
<Channel name="red" path="colors/"/>
<Channel name="green" path="colors/"/>
<Channel name="blue" path="colors/"/>
<Channel name="shutter" path="shutter/">
<Level end="7" fixed="TRUE" name="open" start="0"/>
<Level end="255" name="strobe" start="8"/>
</Channel>
<Channel name="color_presets" path="color_presets/">
<Level end="10" fixed="TRUE" name="no_function" start="0"/>
<Level end="60" fixed="TRUE" name="index" start="11"/>
<Level end="110" name="fade" start="61"/>
<Level end="160" name="pulse" start="111"/>
<Level end="210" name="transition" start="161"/>
<Level end="255" fixed="TRUE" name="audio" start="211"/>
</Channel>
<Channel name="colors_selection" path="color_presets/"/>
</Channels>
</Mode>
</Model>
Re: Help Import Fixture FIle
We have two software versions: TheLightingController Classic (V9) and TheLightingController II.
Each version has its own forum: https://thelightingcontroller.com/
The fixture library formats are different.
TheLightingController Classic (V9) uses TXT files.
TheLightingController II uses XML files.
Please let us know which software you are using, and we will provide you with the appropriate library.
MattCarlsen
version I am using
version 9.4.5 - 260225 x64
thanks!
So please post the profile requirement in this forum here: https://forum.thelightingcontroller.com ... m.php?f=25
with a link to download the manual, and we will do the profile for you asap.
