request - Make shift slider midi-mapable
Posted: Fri Aug 02, 2024 2:42 pm
by rentashow
I was wondering if it was possible, for generated pan&tilt buttons, to be able to midi map the shift slider as well. Manually adjusting this tiny slider takes to much time at a show.
Thank you!
Re: request - Make shift slider midi-mapable
Posted: Sat Aug 03, 2024 6:37 pm
We do not see how we could do that.
Could you please tell us how you see that procedure ?
(with screenshots if possible)
Posted: Sun Aug 04, 2024 2:58 pm
by rentashow
My first thought was adding a "triggers" button to the "button settings" > "Channel" section. Maybe behind the "shift slider" checkbox?
So every shift slider can be mapped to whatever anyone wants. Some may map every shift slider to one single midi control, others will maybe use multiple.
Posted: Mon Aug 05, 2024 12:40 pm
Noted, but we are not certain this would speed up the procedure.
Please note that the midi fader switches on the button too, so linking more than one button with "shift" slider to the same midi fader will not work.
Posted: Tue Aug 06, 2024 10:21 am
by rentashow
The midi-mapping of the shift slider, in my opinion, must not switch on (or off) the button. It just has to adjust the shift slider position.
Posted: Tue Jan 20, 2026 5:55 am
by EKO-LSS
rentashow wrote: Tue Aug 06, 2024 10:21 am
I know sometime has passed on this.. but i do hope that the developers are considering this.. this would be a nice touch.
Posted: Tue Jan 20, 2026 11:09 am
Please follow here for this thread:
viewtopic.php?t=62
We close that one due to duplication.
