request - Make shift slider midi-mapable
rentashow
Post by rentashow »
I was wondering if it was possible, for generated pan&tilt buttons, to be able to midi map the shift slider as well. Manually adjusting this tiny slider takes to much time at a show.
Thank you!
Re: request - Make shift slider midi-mapable
We do not see how we could do that.
Could you please tell us how you see that procedure ?
(with screenshots if possible)
rentashow
Post by rentashow »
My first thought was adding a "triggers" button to the "button settings" > "Channel" section. Maybe behind the "shift slider" checkbox?
So every shift slider can be mapped to whatever anyone wants. Some may map every shift slider to one single midi control, others will maybe use multiple.
Noted, but we are not certain this would speed up the procedure.
Please note that the midi fader switches on the button too, so linking more than one button with "shift" slider to the same midi fader will not work.
rentashow
Post by rentashow »
The midi-mapping of the shift slider, in my opinion, must not switch on (or off) the button. It just has to adjust the shift slider position.
EKO-LSS
Post by EKO-LSS »
rentashow wrote: Tue Aug 06, 2024 10:21 am The midi-mapping of the shift slider, in my opinion, must not switch on (or off) the button. It just has to adjust the shift slider position.
I know sometime has passed on this.. but i do hope that the developers are considering this.. this would be a nice touch.
Please follow here for this thread: viewtopic.php?t=62
We close that one due to duplication.
