3D View not updating [fixed]
3D view of the lightshow
NotBee
Post by NotBee »
When i select a fixture in the fixtures nothing happens in 3d when i create a new fixture i need to press network settings then "ok" and it shows the fixture but beams or phasers don't show in the 3d view
Lightshow.zip
The lightshow
(5.7 KiB) Downloaded 1540 times
Re: 3D View not updating
Please try in Generator with:
- shutter > open
- CYM > on
- iris > open
- pan/tilt > on
- dimmer > 100%
We see that here with that:
https://ibb.co/TDKRXNWF
EKO-LSS
Post by EKO-LSS »
I Just updated TLC to version V_II-0.131 - Dec 18 2025 -x86_64 about half an hour ago
and off the bat am experiencing a similar issue. I am seeing the fixtures in the 3D window, but they are not responding.
Am using the very same light show from the previous version, up until the update everything was working fine.
I am unable to return to the previous version due to not having the install file.. I have a gig in 2 days...help needed.
We have the same lightshow and the same software version than yours.
If the fixtures are not responding on your PC, there is a chance the reason comes from your PC.
Please try on another computer and tell us if it still does not work with it.
EKO-LSS
Post by EKO-LSS »
As of now, i won't have access to another computer until tomorrow. The gig is Tomorrow.. The 3D and everything worked fine on the October version.
Did the original poster of this thread had their issue resolved? if you think its a pc based issue, where do you think i should start troubleshooting? also can you provide a download link to the October version?
regards
I just downloaded and installed the original sweet light on my laptop, version 9.4.1 - 27 July 2025 and the fixtures are responsive in the 3D window.. i can see the Beams and movements of the heads... help needed.
I can also confirm that after updating my desktop a few minutes ago from version V_II - 0.1.26 - Oct * 2025 - x86_64 to this newer December version am experience the same issue.. where the October version worked fine with visuals in the 3D window. now i only see the fixtures. (i was referring to another laptop when i said i wont have access to another computer until tomorrow).. my head is all over the place trying to fix this.. sigh..
We just discovered that you replied in another user’s thread, which caused some confusion.
The lightshow we tested is therefore not yours.
Please send us a link to download your lightshow (viewtopic.php?t=47), and we will check it.
PS: usually, no reply means everything is fine. In other words, the original poster’s issue is considered solved.
Thanks to the lightshow provided in this thread:
viewtopic.php?t=336
we were able to identify a possible issue with version 0.1.31 on Windows.
A new version 0.1.34 (Windows only) is now available via the standard download link.
This release fixes the issue we identified.
