Palettes / presets
Dumbfungus
Palettes / presets
Is there a function similar to palettes? I want to have pre-defined positions for my moving fixtures. I would like to be able to set different pan positions, and tilt positions. Then be able to mix and match.
Re: Palettes / presets
Not now.
Noted.
Noted.
+1, or like save shape function
Regarding the word "palette".
Solution #1
It is ok whether this palette is a pan/tilt position that can be saved from one scene and loaded in another one. And afterwards, if you want to change this pan/tilt position, you will have to change it in all scenes.
Solution #2
Or does this palette have to be an ID linked to a pan/tilt position. Afterwards, you can change the pan/tilt position and all scenes using this ID will automatically have the pan/tilt position updated with the new one ?
To know:
first case should be quite easy to achieve, while the second one is another story.
Solution #1
Solution #2
To know:
Dumbfungus
I really like the way it works in the previous v9 software. I can save specific RGB combinations , xy coordinates , etc.
I’d like to be able to define settings and use them in scenes. So if I update the setting then all instances of that will update automatically.
Thank you for this information.
This is noted.
This is noted.
++++++1!!!! This is what is keeping me from using this program. Why can't you save a color or a pan tilt position that you can easily open in generator. Seems to me this should be a given with a program like this.
Looks like you are asking for "solution #1", while "solution #2" was previously asked in this thread.
Noted anyway.
Noted anyway.
