How to program a chaser with BPM ? [fixed]
create scenes
LKa84
Post by LKa84 »
I may have a similar problem. I can programme a chaser in the generator using the dimmer channel of the LED bars, but I can't modify the speed in the board using the BPM function.
How do I go about programming a simple chaser that can be controlled with the BPM function?
LKa84
Re: How to with an LED bar?
Post by LKa84 »
Is that more a board theme?
Re: How to program a chaser with BPM ?
Please post a link to download your lightshow (viewtopic.php?t=47) and we will check that.
LKa84
Post by LKa84 »
Ok i create a folder in my google drive:
https://drive.google.com/drive/folders/ ... sp=sharing
You can do like this:
LKa84
Post by LKa84 »
First of all thank you very much for showing me this workaround with setting the generator to 80 or higher seconds. Then it worked, but only for 10 sec.
I play a little around with the generator and shorter or longer times but after a few seconds all lights switch off and turned after a few seconds again on.
How does the generator effects the BPM mechanism?
I´ve create a little sample video it:
LKa84
Post by LKa84 »
Another small thing: Beams didn't work for me.
May be there is something in the 3D view that I have to adjust?
It may be possible that the time counter does not reset correctly after each new beat/BPM.
We will check that asap and we come back to you.
PS : no way to read your video because it is "private".
Regarding the beams in the 3D, please read this: viewtopic.php?t=226
LKa84
Post by LKa84 »
Oh sorry, yeah I switch the video to listed.
Thank you very much.
And beams are working now.
And I upload the new Show here called DJ setup 2
There I played around with this huge time in the generator https://drive.google.com/drive/folders/ ... sp=sharing
Please proceed like this, this is easier.
