Works with V9 and not with V_II
USB to DMX - 1024 channels
Yehor
Post by Yehor »
I have a D1024 device. I installed the driver, and the device is recognized, but it does not respond. I created my own device profile and assigned channels, but it still does not work. It was working perfectly on version 9, but now on my current setup it doesn’t respond. Could this be related to my laptop? Can you help me resolve this issue?
Re: Works with V9 and not with V_II
We will try to help you.
First of all we need more details.
Please keep in mind that the only things we know are the things you tell us.
Operating System ?
V9 and V_II are on the same PC ?
The welcome screen shows "interface found" ?
The USB LED blinks ?
A video may help us to understand more quickly the problem ...
Yehor
Post by Yehor »
I read something and it turns out that the program does not work on 10 windows quite well because the interface is displayed and it is very strange why 3D does not work devices are added redim editing I turned off and they do not respond in any way if you need a video I will take it off I just have a job so I downloaded the driver on the v9 version to work
The 3D has nothing to do with the DMX. There was a problem with the 3D under Windows only and it is fixed in the new downlodable version (0.1.33).
V9 and V_II work well under Windows 10, as well as Windows 11.
The same USB driver works for both V9 and V_II.
We look forward to see your video.
Yehor
Post by Yehor »
Well, this is a settlement on the video where you can see that the program does not respond to 3D in any way https://youtube.com/shorts/idmXhIPAuws? ... dl10zIfWaN
Yehor
Post by Yehor »
Then I'll send a video of the device not working in 11v
This is the problem we were telling in our previous post.
3D problem in version 0.1.31.
Fixed in version 0.1.33.
Yehor
Post by Yehor »
Okay, but I can't find the new version, can you send the link where to tell me or the file itself
viewforum.php?f=5
The new version is only for Windows because version 0.1.31 has no problem with the other OS.
Yehor
Post by Yehor »
Thank you for the help, I looked so much, it turns out that now my iPad will not be able to control because there is a 1 version less when the update will be released in the iPhone?)
