Master fader dimmer does not act on channels [fixed]
Terralec1
Post by Terralec1 »
If I am using a PAR fixture with other colours other than RGB, can these be controlled in the boards screen? ie my fixture has a UV channel.
I have tried setting up fader board, but i can only ever get control of RGB.
thanks
Re: RGBLAUV
It works here.
The master fader acts proportionally on all these channels.
Terralec1
Re: RGBLAUV
Post by Terralec1 »
I can see you can select the channels for faders. But in the board screen i can only control RGB, i can only control RGB when Colour board is turned on.
But cannot seem to control white\UV/Amber channels on the faders.
See my screen shot, I have a fader for All channels and faders for red, green, blue, white, amber, UV.
But i cannot control white, amber and UV. Only RGB when Colour board is turn on.
thanks
Re: RGBLAUV
Could you please post a link to download a zip of your lightshow ? (viewtopic.php?t=47)
We will check that.
Terralec1
Re: RGBLAUV
Post by Terralec1 »
Please use this dropbox link.
https://www.dropbox.com/t/8Kofs3dt29b3gV3u
thanks
Re: RGBLAUV
The "Master Faders" act proportionnaly over the current level given by other buttons.
You have to create a scene where the channel is on.
Then the Master Fader will act on it from -100% to -0%.
Terralec1
Re: RGBLAUV
Post by Terralec1 »
OK thanks, understood.
